Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: FAST 90mm Throttle Body
  1. #11
    casey23 Guest
    Hey Red.. I have a 105mm Accufab... Its there Universal Fit unit.... 300.00 brand new in the box...
  2. #12
    I'll keep that in mind. Right now it's the wrong time of year to be buying stuff for myself. I'll have to wait a few months.
  3. #13
    Jun 2007
    is there such a thing as these beeing to much for youre application,are they adaptable to dbw?and what mm would work good on my setup ?i tried 1 of bbks 78mm and all i kept getting with 2 of them was reduced engine power.so i sent em back .couldnt getem to run on my damn truck ,is this a common problem with dbw.how would you guess what size would be to big ,how do you reference it ?seems like alot to jet a carb and it be wrong size.dont know just wondering id like a nice setup,like these.
  4. #14
    May 2004
    It all depends on your mods. Yes, you can have too much. Boosted applications seem to work well with larger TB's though.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
  5. #15
    Boosted by SC needs the bigger TB. By turbo its not quite as important, it gets forced through the smaller TBs.
  6. #16
    Apr 2005
    It is really important for the maggie guys, since it draws through the TB first.
    Centri's like the Procharger push through the TB similar to a turbo so it isn't as important.
    Gone, but not forgotten!
  7. #17
    What he said.
