Results 11 to 20 of 25
Thread: T-56 Swap
  1. #11
    Castro Valley, CA
    The main Benefit of having a T56 is it can take more power... Stock its suppose to beable to take 750 hp.... The stock nv3500 is only good up to 280 hp i believe... So even if you upgrade the clutch or something on the NV3500, there's still parts in there that will break after enough high power abuse
    (disregarding the freak transmissions that will take more power, and the clutch too.... Like some of those trucks, where you can put too of the same stock trucks next to each other, and one will be faster than the other)
    .... The T56 on the other hand will be good..... For me too i'd like to eventually put a 6.0 in my truck, or maybe a duramax, and i'll won't have to worry about my tranny at all.
    2004 4.8l 6 speed manual 2wd
    Looks: 22" foose rims with Fierce tires, SS front bumper, SS Front Grill, 2/3 lowering kit.
    Performance: Volant Intake, 3" exaust with Spintech muffler, Pacesetter LT's with Y pipe, TR cam 220/220 .551 112 lsa, T56 Tranny with the Keisler short Shift kit and LS7 Clutch, Quicktime Scatter Shield, ASP Underdrive pulley kit, Dyno tune by Rick at Synergy Motorsports
    Soon to Come:Eaton locker, Electric Fans..Does it ever End?
  2. #12
    May 2007
    I thought nv3500's were rated higher than that. But I'm on the look out for a t-56 myself hopefully I soon I can use your guide and make the whole process a little easier.
    It's true I think RST does stand for Real Slow Truck.
  3. #13
    what would possess you to take a trans to Aamco?
    usually a 40k mile trans should only need a fluid change
  4. #14
    Castro Valley, CA
    I took my trans to AAMCO, because they said they would do the whole swap for 200$.... Like swap my nv3500, and put in my t56 ready to run for 200$... I gave them all the parts i had and so basically i was just paying labor... but it didn't work that way.
  5. #15
    well i have well over 500 ft lbs on my t56 and it takes it like a cherry. Most manual transmissions are very strong, most of the time when the break its from driver error. As long as your not going for crazy amounts of power i wouldn't worry about it. 4:56+ gears 6.0 liter, t56, and a nice ls7 clutch you'll be good to go. Unless your F/I or have some big bucks in a 6.0 your not gonna get anywhere close to enough juice to bust a t56 IMO
    2005 GTO - somewhat stock
  6. #16
    Castro Valley, CA
    ya... there's no way my little 4.8l is going to be putting out 400lbs of torque... So for right now, i think this tranny will hold up great, then in like a year or so i'll build a motor, or put a 6.0 in it, and have the tranny upgraded at the same time....
  7. #17
    Hutto TX
    nice~!! What is left before you can drive it? Do you have a part number for the pilot bearing? I could suuure use some pics of the motor mount on the x-member!
    1991 Silverado ECLB
    LM7-T56
  8. #18
    Jun 2007
    maine
    the part number on my pilot bearing is 14061685
  9. #19
    Castro Valley, CA
    Quote Originally Posted by r6z4o6 View Post
    you need some pics of how the motors mounted?
    or you want some pics of the tranny x member? i can get either.... or both whatever you need
  10. #20
    Any updates?
