Results 11 to 20 of 30
Thread: Dtc P2761
  1. #11
    You try sending Randy a PM?
  2. #12
    Aug 2005
    St. Anthony, Indiana
    I'll try and scan that page for you tonight.
  3. #13
    Step 3 asks is the fuse open.
    Is it?
    Open when discussing fuses means blown.
    Is it?
    If so the chart will have you search for shorts. If it's not open it will have you check the power supply circuit to the fuse for an OPEN.
    Most likely you have a bad ignition switch if the fuse is OK.
    Take a deep breath and don't make it harder than it is.
  4. #14
    Dec 2009
    ttt Im still driving the 09 silverado meanwhile I wanna get the other one fixed
    I unplugged all the connectors to the transmission, as well as i played with the harness..moving it from the engine to tranny..
    I unplugged the battery 10 minutes, started the truck back, cleared the codes and the truck ran fine for two weeks, the same codes came back again!
    no more 1-2 gear in two wheel drive, but I have the 1-2 in awd and 4x4
    pretty weird!!
    please help me!!
  5. #15
    Dec 2009
    Really appreciate the confidence you guys are giving me!!! thanks
  6. #16
    Aug 2005
    Quote Originally Posted by Nick1 View Post
    I am stuck at step 3, I don't have the page 8-910,
    p. 8-910 just shows you what a blown fuse looks like. Follow Gasguzzler's recommendations.
  7. #17
    Dec 2009
    Is it?
    Is it?
    Okay, I get it, but where are theses fuses? Can someone kind of show me where exactly are the fuses
  8. #18
    Dec 2009
    Why would an ignition swith cause transmission silenoid codes?
  9. #19
    Dec 2009
    Can someone find me a ignition switch off the internet...
    a link or something that would direct me to buying one ...the right one..
    But before I need to make sure it is the switch....
  10. #20
    Dec 2009
    ttt
