Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: Cabin Air Filter!!!
  1. #11
    Jul 2006
    College Station, TX
    Yeah i am going to do the filter when i change my break pads. and have my rotors turned.
    2004 EXC Silverado 6.2L
    Mods:
    6.2L L92, Ported and Polished stage 3 heads, 95mm Throttle Body, 100mm MAF, NA, Pacesetter LT Headers, Magnaflow X-Pipe Muffler, Electric Fans, 160* thermostat, 2" Drop Shackles, Hellwig Sway Bars Front and Rear, Monroe Reflex Shocks, NGK Spark Plugs, AMW Oil Catch Can, 17"x10" wheels on Kuhmo Tires.
  2. #12
    <div class='quotetop'>QUOTE(shwarmy &#064; Mar 21 2007, 12&#58;04 AM) [snapback]86832[/snapback]</div>
    I&#39;ll take that as you&#39;re not going to be doing your brakes then
    The &#39;03-&#39;07 Classic do not have the cabin filter
    2007 Sierra Denali, 6.2l L92, 6L80E, 3.42s, AWD, Outlaw CAI, 160* t-stat, magnaflow muffler and HPTuners!
  3. #13
    Sep 2004
    Breaux Bridge, LA
    <div class='quotetop'>QUOTE(shwarmy &#064; Mar 20 2007, 10&#58;04 PM) [snapback]86832[/snapback]</div>
    if you read above they only said up to 02. can anyone confirm this?
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    10.35@130 pump gas LQ4
    Knothead Racing
  4. #14
    <div class='quotetop'>QUOTE(bluecajun5.3 &#064; Mar 21 2007, 08&#58;23 AM) [snapback]86857[/snapback]</div>
    Ok, well, I looked and looked...but I had to resort to calling O&#39;Reilly and they said &#39;03 and up did have one. They aren&#39;t always right, but just as an extra measure, I would consult the owner&#39;s manual...
  5. #15
    San Marcos Texas
    <div class='quotetop'>QUOTE(duckysbht &#064; Mar 20 2007, 07&#58;29 PM) [snapback]86795[/snapback]</div>
    I think it&#39;s time you put up some pictures of this new beast you got jeff. I&#39;d like to see it.
    I&#39;ve been taking off the emblems and side moulding so maybe tonight I&#39;ll take a few.
  6. #16
    <div class='quotetop'>QUOTE(txarkitekt &#064; Mar 21 2007, 01&#58;14 PM) [snapback]86884[/snapback]</div>
    I will look for the filter tonight in my &#39;06 and I will check the owners manual too. I know my &#39;04 ext. cab didn&#39;t have one though
  7. #17
    Jan 2006
    TAKE THE BTTM COVER OFF OF THE UNIT INSDE THE CAB. THERE WILL BE A DOOR WITH I THINK 2 SCREWS ON IT AT THE RIGHT OF THE UNIT AT THE BTTM. OPEN THE DOOR AND THERE WILL BE 2 FILTERS THAT ARE SLID IN PULL ONE OUT THEN THE OTHER IS RIGHT NEXT TO IT. PRETTY EASY, IT JUST TOOK ME A WHILE TO FIND THE FILTER DOOR.
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
  8. #18
    <div class='quotetop'>QUOTE(Jamest &#064; Mar 22 2007, 11&#58;38 AM) [snapback]86995[/snapback]</div>
    JAMEST
    James, what year is your truck? It&#39;s a 3/4 ton, right?
  9. #19
    Jan 2006
    <div class='quotetop'>QUOTE(txarkitekt &#064; Mar 22 2007, 03&#58;40 PM) [snapback]87032[/snapback]</div>
    I&#39;M SORRY. I DIDN&#39;T THINK YOU COULD FIND IT. I SHOULD&#39;VE READ FURTHER. GLAD TO HEAR YOU FOUND IT. I NEED TO CHANGE MINE A GAIN.
    SORRY FOR THE MIX UP.
    ITS A 2000 MODEL. YES ITS A 3/4TON.
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
