I have to be at work at ****ing 2:00 so I am heading over there as soon as I wake up, maybe I can get a run in before I have to head back to Burleson. Anyone know the exact address or exact directions? (from 820 and I30)
4551 w bailey boswell rd
ft worth tx 76179
right? I hope so cuz thats the address I found.
06' rcsb silverado H/C/I/N2O 5.3
got my roll cage installed, see you guys at the shop
im heading out after i finish some food, see ya.
got my new plugs yesterday put them in this morning then clean the truck alittle and then i am on my way bringing a buddy with a 04 v max should be out there around 11:30
[SIGPIC]5.3 k&n cai ,asm lt, hf cats, aero turbine muffler, vhp 216/224-551/551-115lsa, tbss intake, ls2 90mm tb,tb bypass, comp double roller tc, hv oil pump, ls2 injectors,nelson tune, b&m super cooler, taylor 10.4mm wires, ngk tr55ix, 373 Detroit tru trac,
Well, biggest pull of the day trophy goes to your's truly. Engine plus 93 nitrous and 41 fuel jets on the Nitrous Outlet plate system, single stage.
Temp 98.42 degrees
29.74 in-Hg
20 percent humidity
Max Power 597.53 HP
Max Torque 520.30 ft/lbs
not so great...i got the lowest number of the day!!!
233hp!
videos,videos,videos!congrats red,nice mumbers.how much hp did you gain with the nos?just curious.close to 600.
about 230 on the NOS. I didn't make any NA runs since the timing is retarded about 8 degrees and won't run too well like that without juice assist. Everyone made some awesome numbers. They even threw a Mazda up and it made about 83 hp on a 4 cylinder engine. Don't feel bad if your numbers aren't that high, there's always someone slower or faster. Our boy Lambchop made a grand entrance, throwing the rental car into a screeching Ebrake power slide while steering into the parking lot. Cowl pushed almost 400 HP with the assist of Mean05 and a dry shot of nitrous being hand fed into the intake manifold. It was a great day with a lot less particapants than we expected but it was a good time. Got a ride in ChevyLee's truck, very impressive.
sounds like alot of fun ,man i wish we had a club or something up my way to do stuff like that .and i hope you werent referring to me not having 83 hp.lol.i want to see this force fed nos deal .cant wait to see some vids and fun yu guys had.i got excited today just to spank a srt 8 gc.if i was theyre id have higher blood pressure than i already do .lol.i just get pumped for u guys.
