Page 17 of 19 FirstFirst ... 7 15 16 17 18 19 LastLast
Results 161 to 170 of 183
Thread: 6.0 into 98 OBS
  1. #161
    Sep 2009
    NE Ohio
    I am having issues with my O2's. P0134 & P0154 No activity bank 1 sensor 1 & bank 2 sensor 1. I have been reading that when you have LT Headers these codes will pop up. I also read that switching the rear O2's to the front, solves the problem. Something about heating time is not enough with the fronts because of the free flow of the exhaust.
    Anybody else have this issue with their swap?
    Been lurking since 09 and I finally have my kickass 6.0 LQ4
    LQ4 LQ9 6.0L Engine Service Manual Save to your computer in case it disappears
  2. #162
    May 2007
    Medford, OR
    Are they heated O2s? If not, change them to heated ones and it should solve the issue.
  3. #163
    Sep 2009
    NE Ohio
    Quote Originally Posted by ccreddell View Post
    Yes they are. They are the same ones used from the donor vehicle. Which are new by the way.
  4. #164
    Mar 2008
    GREAT thread! Thanks for the time in posting/describing/vids/diagrams and all who have chimed in.
  5. #165
    Sep 2010
    So in a nutshell, the 411 ECM can properly run a DBW setup with cruise control? Are there different versions of the 411 PCM?
  6. #166
    Sep 2009
    NE Ohio
    Quote Originally Posted by BOTTLEDZ28 View Post
    My donor setup was originally a DBW. The original cruise control was tossed out and the TAC module actually mounts in the exact location as the cruise and I pinned the OBS cruise wires directly to the new TAC module for a seamless install. If you need wiring diagrams for that let me know as I have access to Alldata and that really helped me through the entire wiring process.
  7. #167
    Sep 2009
    NE Ohio
    I am loving my swap. It hauls ass and goes fast. I do have an issue with the Bank 1 Sensors 1 & 2 due to the oversized exhaust and the fact that the tops of the headers are not sealed properly because of the o2 bungs that Schoenfeld put so close to the ends of the collectors. But I am thinking of goes speed density anyways so I can eliminate them and fix the exhaust leak.
    Up next is a limited slip rear end. Maybe it will help with the snow or I will just park the truck and drive the lil corolla hoopty for the winter. I cant even keep the "tire" from spinning when it is wet out. I cant even imagine what it will be like in the snow.
    I cant wait to do another LS swap. May even do a carbed version on the next one. Juat trying to locate another motor and use my 5.0 vortec as a core for the new one.
  8. #168
    Sep 2010
    Quote Originally Posted by capricefrk013 View Post
    Id love to get a hold of any wiring diagrams you may be able to offer me. My truck is 98 2 door Tahoe 4x4. 350 Vortec. email info to bottledz28@aol.com
    Thank you.
  9. #169
    Sep 2009
    NE Ohio
    Just get me a list of what you need and I will shoot them your way. Hell I still have a stack of them in my truck from doing mine. Give me some time on it as I have to print them and then scan them so I can email them. Alldata wont allow you to do anything but view it on the desktop.
  10. #170
    Sep 2010
    I basically would need any diagram that would be useful for doing a GEN 3 swap into my 98 2dr 4x4. I dont have an engine picked out yet so it may be DBW or DBC. Not sure what I will end up with. Right now, I have Lextechs diagrams with the intentions of using a 411 ECM. If there is a simpler way then let me know.
