Page 15 of 18 FirstFirst ... 5 13 14 15 16 17 ... LastLast
Results 141 to 150 of 178
Thread: 94 Lifted Silverado 6.0/4L80e swap Build
  1. #141
    Jun 2009
    Caledonia, MI
    Quote Originally Posted by RPM Graphics View Post
    i have a Nelson harness too & didn't have to hook anything up to the brakes, & i don't have a neutral safety switch, & mine shifts & stops just fine.
    how's your idle when you try to stop, is it high?
    My idle is just fine. Warm and cold. I dont have a accurate reading bc My tach is way off and I need to call Nelson to see if they can fix it/ recalibrate it with me sending my ecm back in. But I do know its idleing about right. Sounds like its between 600 and 1000. When I try to stop it might rev up a tad because it wants to leep forward but then ends up stalling if you dont put it in neutral.
  2. #142
    Jun 2009
    Caledonia, MI
    Pic updates
    Heres some pics of my 3" exhaust from the headers back to a y pipe, through a electric cutout, then a flowbasterd, then back to duals.
  3. #143
    Jun 2009
    Caledonia, MI
    More pics and another question
    Does anyone know what this connector is for?!?? It is braided and shielded (has a protective caseing around it) And then it also has a black wire with a white stripe. What Im trying to figure out is where that black wire with the white stripe goes. I want to say its a ground but I am not rreally sure. The 2 wires coming out of that connector is purple w/ white stripe, and green with black stripe.
    the first pic is an exhuast bung for my air fuel ratio gauge.
  4. #144
    purple and green wires are your OBS speedo wires. Black with white is ground 99.9% of the time.
  5. #145
    Jun 2009
    Caledonia, MI
    I bet thats why my speedo doesnt work then lol. I love solving problems. Hey red while you r online i need you to help clarify things about ur reply on my earlier post about the brake switch and torque converter unlock
  6. #146
    Jun 2009
    Caledonia, MI
    Power may be coming from Blue PCM connector pin 19 or it may be wired into the power lead that is going to the 4 wire connector for 12v power, could be switched or always on.
    So is that all I do is take pin 19 from the blue connector and wire it into the power lead on the brake switch?
  7. #147
    no no no. The PCM would supply voltage to the transmission. I prefer that the power for the transmission comes from the brake pedal switch. Look for the lead on the brake pedal switch the has 12v with the pedal at rest and 0v when you push the pedal down. Did you see the recent posts I made for Myzterry about the wiring diagram for the transmission. I think it's terminal E on the connector that has a pink wire to it and it's supposed to have that 12v source going to it from the brake pedal.
  8. #148
    Jun 2009
    Caledonia, MI
    No I didnt see your post on Rays Thread so I will go look at that. I understand that I need to have the brake switch with 12v constant and then once its pressed its an open circuit so 0v, so what do i do once I find that wire and confirm that is has 12v and then 0v when brakes r applied
  9. #149
    Jun 2009
    Caledonia, MI
    Ok I think I get it now, all I need to do is run my brake switch wire to that terminal e on the tranny connector.. I found your post and yes it was terminal E, IF that connector is the same connector on my 4l80e.
  10. #150
    hang on, let me verify for sure.
