Page 15 of 44 FirstFirst ... 5 13 14 15 16 17 25 ... LastLast
Results 141 to 150 of 436
Thread: my first ls swap 1996 2 door Tahoe 4wd 385 Stroker to LQ4 cam headers **pics**
  1. #141
    looking good man keep up the work.
  2. #142
    Sep 2011
    Atlanta Ga
    Quote Originally Posted by Pete View Post
    looking very nice! Lucky you have good weather in Cali.
    thanks. yes weather is beautiful out here. we had a little rain the other day but thats about it.
  3. #143
    Sep 2011
    Atlanta Ga
    thanks alot. its comin along..
  4. #144
    May 2010
    Galveston, Tx
    Before and after elongating pics of the flexplate?
    95 C1500 LM7, built 4L60e, Circle D 3200, LT's, Nelson tune, open differential, 3.42, and LS1 e-fans. Tractionless
  5. #145
    Sep 2011
    Atlanta Ga
    Quote Originally Posted by silverado_lover View Post
    i dont have any pics of when i finished it. only before. but i only had to extend the holes about 1/4 inch on each and it worked perfectly. well we will see when i get it started.once i had finished i was so excited it fit i bolted it up and dropped the engine in
  6. #146
    May 2010
    Galveston, Tx
    I would probably do the same
  7. #147
    Sep 2011
    Atlanta Ga
    yea man i was real happy to finally get it off the ground and in the engine bay. but stupid mounts didnt line up and the engine is too far forward. should have got the dirty dingo mounts at first. thats what i get for being cheap.
    but i test fit my harness and all the plugs are there. only one outstanding was low coolant plug so i gotta see why that stlll there. i test fit the headers and they fit great. when i get some money ill get the pcm starter intake and pedal and start her right up hopefully.
  8. #148
    Sep 2011
    Atlanta Ga
    Had to put this project on hold a few days because a friend of mine needs help removing the engine out of his crashed z28 camaro. actually it might work out for me because i might score a 2wd trans. but i was able to start putting the engine together now its dropped in. also im still working on the harness.
    couple shots of the intake and stiff back on the engine. ( i realized after i was done that the fuel rails were on backwards...blame it on the 4 coronas)
    mocked up the wiring before i insulated it to make sure im not missing any plugs. it was dark sorry
    got the stuff in the mail to finish up the harness. fuse block ob2 port and relays and all the connectors. so hopefully ill get the harness finished this weekend. its freaking tedious i gotta be in the mood to tackle that thing. no rush luckily because i still need to order my starter and cpu finished the fuel lines etc.
    i also got to keep the electric fans from my buddies lt1 camaro so looks like ill be fighting with that clutch fan after all.
    also just found some pics the old lady took when i pulled the trans and reinstalled the cpu.
  9. #149
    what mounts did you use that didn't line up?
    do they only have 1 hole? i was going to get the DD mounts but bought a set with 3 sets of holes, 1" forward, center, & 1" back.
    i guess i'll soon figure out which hole i need, LOL!!!!
  10. #150
    Sep 2011
    Atlanta Ga
    Quote Originally Posted by RPM Graphics View Post
    they were some ebay mounts for $30 bucks. i shoulda known! im going to order these http://dirtydingo.com/store/product_...oducts_id=1367
