What are the differences between a 96-98 4l60e's? Do they have the same plugs?
From what I have been told by the Brendan Patton(the guy who flashed my PCM on LT1 swap) you will need a Vehicle Speed Sensor(VSS) from the tail shaft of the transfer case. I think 93 and up had them. If you don't, you will have to either buy a different T-case with the sensor, or buy an aftermarket speed sensor. The reason being is that the 4L60E is an electronic transmission and is shifted by the PCM. Without the pulses coming from the VSS, the PCM doesn't know when the vehicle is moving or stationary.
When using an older trans that shifts by vacuum modulator, the VSS is un-necessary.
As for bolting up, it may. You may be better suited to finding a Tcase from a 93 to 98. That will have the VSS and should bolt up to the 4L60E. Mine did and I'm running a 99 4L60E out of a Caddy Escalade originally powered by the traditional small block Chevy 350 with Vortec injection. I still retain the original T-case.
John
John
I ended up removing my old adapters out of my trans and installed them into the 99 trans. The male threaded part are metric in both but the female part that receives the cooling line was different. In order to keep my original cooler lines, I simply swapped fittings out of my old trans and put them in the new one.
John
John
What about the oil cooler lines? Will they bolt to the 96-98 truck radiator? I haven't read or heard anyone say anything about these.
i would think the line would work. i put an 02 F-body 4l60e in my 96 & i used my 96 lines, just had to bend them a little to fit. the angle they go into the trans is a little different.
i know you're talking about a truck trans but if the f-body is the same i would think the newer truck is the same.
my 96 also has 2 sets of holes. i actually used the forward set on one side & the rear set on the other & my trans lined up perfect in the center. if i would have used both rear holes it would fit but the trans mount stud was all the way against the front of the cross member.
It's seams everyone is just buying the block off plate. But I would like to retain the oil cooler,but the block off plate is much cheaper that the 150.00 adapter plate that allows you to run the an fittings.
Are there any longtube headers out there that will clear on a '96 4x4 rcsb?
