Page 11 of 12 FirstFirst ... 9 10 11 12 LastLast
Results 101 to 110 of 119
Thread: silverado_lover's LM7 swap
  1. #101
    Feb 2011
    Mobile, al
    Sent you a PM, have some questions. My truck has been down for about a year. It's running, but I would like to change the harness and get the headers...looking for some insight.
    Jose
  2. #102
    May 2010
    Galveston, Tx
    I'll give you a call soon...trying to get my speedo working right quick
    95 C1500 LM7, built 4L60e, Circle D 3200, LT's, Nelson tune, open differential, 3.42, and LS1 e-fans. Tractionless
  3. #103
    Feb 2011
    Mobile, al
    ok
  4. #104
    May 2010
    Galveston, Tx
    Looks like I'll be getting a new trans...it basically turns into neutral for a second during shifts.
  5. #105
    May 2010
    Galveston, Tx
    Truck is at the trans shop
  6. #106
    May 2010
    Galveston, Tx
    Holy hell...this trans is going to make me get new tires, they chirp under normal driving The 3200 stall is also fun
  7. #107
    Dec 2010
    Great info on the fuel system. i'd love to see a full list of connections made to the truck harness when you get everything hooked up.
  8. #108
    May 2010
    Galveston, Tx
    Quote Originally Posted by Wagonbacker9 View Post
    It's all hooked up, I'll check the diagram when I get home
  9. #109
    Aug 2012
    Portland, OR
    Bringing this back up, I am getting ready to put in LM7 in my 95 with an NV3500. I am using the parts 91blkstpsd used for the trans mating, but he had a DBW engine so I can't use his fittings. I am putting in a 2001 LM7. Do you have any pictures of the fuel fittings? Did you just cut the 18" hose with some snips? And on the oil and coolant adapters, which one did you end up using and how did you splice the wires if you didn't use the adapter? Thanks man
  10. #110
    May 2010
    Galveston, Tx
    To cut the AN hose I used electrical tape, a chisel, and a hammer. I don't have any pictures of the fittings but these are the exact fittings I used
    I went with the S&P adapters but search for minime168's thread on the adapters and there's a link to a cheaper source for the adapters and they're not chromed out lol
    Welcome to the site!
