Chevy High Performance did a truck to LS6 to FAST 90 comparo back in 04 or 05. Might ask someone at NP since they were involved in some of the LS testing the magazine did back then.
nice write up
get the LS6 cam and you can feel the pull up high
so the TBSS intake will handle the higher rpm's.
2001 Camaro SS conv. R.I.P.
2005 RCSB: LT offroad Y, G80 3.73, cold air, Zex wet kit 125, 2002 LS6 cam, Nelson Tune, 3400 stall. SOLD
1978 Monte Carlo: 305cid, LT's, duals, 3.73, 1.6 rockers, future LSX
anyone knows if i can use the stock truck 5.3 trottle body with the ls1 or ls6 intake...??? will it idle fine?
"The baddest LS turbo truck" 160+mph
Won't bolt up...different pattern.
Really? It won't bolt up.
Didn't the OP use the truck TB on the LS6 intake? Or did I miss something?
On another note - a guy over at performancetrucks.net did this swap on a 6.0 and he said he used a water pump from a 2007 and up truck. Apparently the pulley is wider on those?
The pump is different...more flat like the Y and F pump but I'm not sure the pulley is wider.
