http://www.denalitrucks.com/sm-files/mark-sig.jpg
But Officer, I swear its just a vacuum leak.
Those red things? those are smog pumps!
2004 Sierra Denali ----- 2/4 drop
LSX 438 TWIN TURBO
LSX Block Video
Block number 00370. Build Date 04/17/2007
yeah im building a 408 using L92 heads and L76 intake for a buddys 96S10 and were going to be using the truck accessory drive and that adaptor woudl work perfect for this engine.
Any chance rick will make another one? He is also doing the cam for this engine im doing, and i need to call him, maybe il ask him about it.
LSX 438 TWIN TURBO
LSX Block Video
getting closer, Exhaust is finished
LSX 438 TWIN TURBO
LSX Block Video
I like that. Nice and tucked. What mufflers did you end up choosing?
LSX 438 TWIN TURBO
LSX Block Video
Looks nice, Is the entire exhaust system ceramic coated???
LSX 438 TWIN TURBO
LSX Block Video
