IMO, compression and leakdown should have been the first things done...
i just did the compression test
90 --- 165
155 --- 180
180 --- 180
180 --- 180
FRONT OF ENGINE
Ouch!!!! If you have access to compressed air then do a quick check and see what the problem is. Take the rockers off the three problem cylinders and hook the air up to each one. You will be able to hear where the problem is. Either leaking from exhaust, intake, or crankcase. Number 8 is definately hurt.
Looks like the #8 ringland got lifted and particles probably got hung on the valves on #6 and #7.
ok cool,i will do that in the morning for sure im tearing into it...this is frustrating![]()
funny how its not running 100% but still pulled a new 5.0 stang on my 22s haha
take the advice from Jon hes more then likely right, which valves you running? if they are the stock l92 valves ( truck ) you more then likely floated one and hit the piston, there not designed for high rpms, you need the ls3 valves the hollow stem and sodium filledthen again id go with ferrea valves
Simple: 408 on steroids!
single digits coming soon!
head gasket....if you look at the reading 6 and 8 are low. take a look at the gasket when you pull the heads and see is there was any signs that it was leaking between the two cylinders
your back firing is you trying to fire coolant!!!! i told you to show your plugs and look carefully for a coolant ring on them.
2014 Xsport- 3.5 Eco boost
412 Motorsports
these the ones i need? are they a direct swap? http://www.lingenfelter.com/mm5/merc..._Code=12569427 i cant find the exhaust valves...i will pull the heads soon,while there off ill do the valve upgrade..if its a piston ,engine will get pulled...shoot a complete ls3 head is only 375.00
