Results 1 to 10 of 38
Thread: Fuel Guage Sender
    Jan 2006
    Does anyone know what color the wire is on the fuel pump and which plug it is in that I need to connect my fuel guage to on a '98? The Chilton book for my truck is useless!
    [1/8 mile E.T. - 8.23 @ 82.86 mph w/1.82 60'] '98swb,4/6drop,20"RozziDeeps on 275/40ToyoProxes '98LS1/4L60E,TRCheaTR cam,Ported TB,Billet MAF ends,MSD8.5 superconductor wires,S&P midlengths,!EGR,!cats,2 1/2" true duals w/X-pipe,Dynomax Ultraflows,TCI 3000,billet servo,TCI deep aluminum pan,3.73's w/Auburn posi; Eclipse CD, Rockford 6 1/2's, Memphis 12's, Punch 200 ix, Punch 500x
    my pump wire is brown and the ground is black. Alldatadiy.com? Maybe Hummertech or NITROUS has a harness diagram for you.
    Jan 2006
    I already fried my Auto meter fuel guage because I went by the chilton book. I went and bought an Equus guage to replace it and I don't want to fry it too. The Chilton manual says its a pink wire that goes to the guage but there is no pink wire coming from my fuel pump.
    Grey wire is power to the pump. Black/white stripe is ground.
    Jan 2006
    Ok, so what are all of the other wires for? Does yours show a purple/white wire?
    May 2004
    Purple is Fuel Gauge Sensor Signal (from VCM to intsr. cluster)
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    Jan 2006
    Ok here is what Chilton is telling me. One schematic that reads 1988-98 c/k wiring says:fuel pump/fuel guage -pink-to fuel guage. Then another schematic reads 1988-98 c/k wiring says:To fuel guage(tank unit)-ppl-W connecter of the instr. panel connector. I don't see a pink wire on either one of the plugs on my pump and I only see a purple/white stripe wire, no solid ppl.
    <div class='quotetop'>QUOTE(NITROUS &#064; Jun 29 2006, 05&#58;07 PM) [snapback]56706[/snapback]</div>
    Thanks Nitrous. Stupid question for ya, where is the VCM?
    May 2004
    I&#39;m at work and I can&#39;t remember if it had a white stripe or not. I&#39;m fixing to leave so I can get you all the information you need from the dealer manual as soon as I get home.
    That&#39;s the old computer you took out.
    97 GMC, 2002 LS6.
    FWIW, generally pink wires are switched power leads and red wires are constant 12V sources. Black and black/wt are almost always grounds. Process of elimination may help. Grey is fuel pump power so there goes that one.
    May 2004
    I&#39;ll check back on this thread when I get home, later bro&#39;s
    97 GMC, 2002 LS6.
