so many intakes which one? right now i got a custom made intake 4 inch stainless aluminum with kn cone filter. Might not be good enough.
00 silverado 5.3, 2005 caddy clip,mods asp pulley,e-fans,3.73s,custom intake,jba shorties,hypertech=14.9@95
There is a variety of different CAI people are using. K&N, AEM, Volant. I myself am going to Install a Volant unless I design something diff for my truck.
Tattoos, Kustoms, Chops, Guns and Pits..........Need I say more? AFTERLIFE KUSTOMS.
Getting ready to put an 82 Chevy 1/2 ton blazer under the knife.
EL JEFE
ROUGHNECK
I would just have a 3-3.5 '' pipe bent and powder coated and put a K+N on the end, and try to shield the filter from engine heat, Some of these cold air kits are way to expensive!
<div class='quotetop'>QUOTE(Tim Z @ Mar 20 2006, 06:09 PM) [snapback]47552[/snapback]</div>Ya some will cost you a left nut.I would just have a 3-3.5 '' pipe bent and powder coated and put a K+N on the end, and try to shield the filter from engine heat, Some of these cold air kits are way to expensive!
[/b]![]()
EL JEFE
ROUGHNECK
The metal intake tubes absorb underhood heat. Use plastic tubing if possible.
DO some sort of ram air or to where the engine is getting as much as outside air as possible.
02 SCSB Z71:E-fans/nelson harness,ASP crank & alt,Volant ramair/k&n,UPD lid,Mac perf tube & elbow,Por & pol bbk 80mm TB/bypass,Meziere elec H2O pump,48# injectors,160 stat,LS6 intake,224/228,.581/.588,110šsep.,Dart 205's,Supermaxx header system,Corsa Sport,MSD 8.5 & coils, NGK #6(indexed), Built 60E,Fuddle 3400/cooler,custom alum ds/billet trans & pinion yolks,Weld chyenne 6D's, BFG kdw's, Nelson SD tune.
I like the Volant because it is enclosed and isnt a metal tubing or box. It also has the port in the bottom of the box for the ram air scoop or just to leave it open for an extra gush of air. Only downside to that port is, if you dont have the scoop or cap it off, filter gets dirtier quicker.
Chris
i have the airaid intake system (not the tube because airaid didnt send me one) just the filter and the shield or whatever. ANYWAY i used the k&n filter recharge kit for the first time, and i was wondering, that oil you spray on it for the last part of the cleaning process, how many coats are you supposed to put on? i just put one coat evenly on the inside and outside. am i supposed to do more coats or is one fine?
One is just fine as long as it is evenly coated and covers all areas of the filter element.
Also, airaid makes a tube for it, they sell it for around $100.
Chris
<div class='quotetop'>QUOTE(chrisj6 @ Mar 23 2006, 10:51 PM) [snapback]48035[/snapback]</div>well i called them twice and they said they dont make it for the 4.3, but if you have a link or something then yeah. cuz id rather have that then my stock one i haveOne is just fine as long as it is evenly coated and covers all areas of the filter element.
Chris
