Results 1 to 10 of 15
Thread: LS1 into 96
    Mar 2006
    Im new here been lurking for a couple of months and reading up on everybodys swaps. My little Supercharged 305 just ain't cutting anymore in my 96 and im thinking of going ls1. I know this topic has been beat to death, but I just wanna make sure I got everything figured out on what works and what dosen't. So far I need a wiring harness, PCM, either a crank adapter or a newer 4l60e, AC relocater or notch the frame, than the fuel pump needs to be upgraded and I guess my throttle cable will work. Also here in GA we have the OB2 diagonostic emissions with the Nelson harness will I pass. What else am I forgetting besides a Case of Bud light and 2 of my buddies? Thanks for the help.
    Electric fans. F-body if you have a 28" radiator. 2005 Silverado if you have a 34" radiator. Engine adapter mounts will be required. Radiator hoses may need adapted. Fuel pump relay will have to be wired in to the PCM/harness. You'll need fuel supply one way or another.
    May 2004
    Hi and welcome strokerace! You can still use you stock fuel pump, throttle cable and cruise control cable. Pretty well told you the rest.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    Mar 2006
    What about the emissions part will I be legal? My understanding the harnesses made are just to get the engine running with no EGR or stuff like and you have to run 2 PCMS at the same time sounds confusing. Seems to me when they plug up to my OB2 port it will not show an engine running correct me if I am wrong. Maybe a Vortec 383 would be a little easier install for me.
    Nov 2005
    ohio
    sup strokerace!
    May 2004
    The only reason to run 2 computers is for the anti-lock brakes. I decided to run 1 PCM and I'll find a way to make my ABS work. As far as emissions go, a vette, T/A and Camaro pass so I don't think there's a concern. LOL
    97 GMC, 2002 LS6.
    Mar 2006
    Well I thought the harness and new PCM was just the basic stuff to make the engine run I didn't know it would take the place of my PCM and all that stuff. I am not used to all the newer engines and what will pass emissions and won't pass.
    Jan 2006
    You can get the harness done however you want it, with or without emissions. The harness & ecm from an
    F-body is pretty much a stand alone system. As far as the diagnostic port goes, you'll have to tie it into your new harness (I have not done this yet) or it will still be connected to your old ecm and it will not be functional. I wouldn't say this swap was easy but it's really not as hard as it sounds, but yes a 383 stroker would be quite a bit easier but definitely not as coool
    [1/8 mile E.T. - 8.23 @ 82.86 mph w/1.82 60'] '98swb,4/6drop,20"RozziDeeps on 275/40ToyoProxes '98LS1/4L60E,TRCheaTR cam,Ported TB,Billet MAF ends,MSD8.5 superconductor wires,S&P midlengths,!EGR,!cats,2 1/2" true duals w/X-pipe,Dynomax Ultraflows,TCI 3000,billet servo,TCI deep aluminum pan,3.73's w/Auburn posi; Eclipse CD, Rockford 6 1/2's, Memphis 12's, Punch 200 ix, Punch 500x
    Mar 2006
    Thats a sharp truck man. What kind of numbers are you putting out or quarter times? Thanks for the explanation I was thinking that it had to be something like that.
    Jan 2006
    <div class='quotetop'>QUOTE(strokerace &#064; Mar 14 2006, 07&#58;10 PM) [snapback]46956[/snapback]</div>
    Thanks&#33; It&#39;s puttin out 328rwhp with some tuning problems(wanting a Nelson tune when I can afford one) and I&#39;ve only been to the track once & ran an 8.74@ 81.52 in the 1/8 mile babying it outta the hole.
