Results 1 to 10 of 18
Thread: 160 or 180 t-stat?
    Dec 2005
    I was just wonderin where to get a 160 t-stat for my 1999 5.3 silverado? or would a 180 be a better option to go with considering the only mods are the turbo kit and injectors and a NELSON tune? Thanks
    http://i76.photobucket.com/albums/j1...o/789547ee.jpg
    1999 Silverado LS RCSB 5.3 Liter (16.02@83.5 bone stock) (with mods ??.?? @ ?)
    STS Turbo Kit (5 psi), GT67, STS Intercooler, 42lb/hrs, 255 Pump, 212 216 Comp Cam, Nelson STREET Tuned, Eaton LSD, 4.11's, Phoenix ReTrans Stage 3 4L60E, 160 t-stat, B&M Supercooler.
    Jan 2005
    Conway, AR
    I'm using a 160, but i dont have a turbo. just cam, exhaust, intake and Nelson tune.
    Chris
    Dec 2005
    so where do you get the 160 t-stat? a parts house? or gmpp?
    Nov 2005
    ohio
    <div class='quotetop'>QUOTE(Turborado &#064; Jan 23 2006, 05&#58;16 PM) [snapback]41972[/snapback]</div>
    i bought a hypercrap 160 stat from summit racing, you could call hypertech to double check the part #, im not sure if you need a t-stat or if you need the complete stat housing.
    Aug 2005
    St. Anthony, Indiana
    Thunderracing.com
    tbyrne.com sponsor on this site
    what is the difference in getting a 160 or 180 compared to the stock one? what does it improve?
    Nov 2005
    ohio
    <div class='quotetop'>QUOTE(duckysbht &#064; Jan 23 2006, 07&#58;29 PM) [snapback]41983[/snapback]</div>
    it lets the engine run cooler and a cooler engine makes more power, allows for more timing. but on a hot day temps still can go over 160-180 degrees.
    i see. how much do 160&#39;s usually run? what does the truck come with stock? should i consider investing in one?
    Nov 2005
    ohio
    <div class='quotetop'>QUOTE(duckysbht &#064; Jan 23 2006, 07&#58;55 PM) [snapback]41987[/snapback]</div>
    uuummm, i think stock is 195 degrees, i think, from hypercrap they are 30&#036; or so, if ya got some extra bucks, go for it i think itll give a little extra power but i like mine cause i like a cool engine, heat kills, besides you can put it in your sig, if you have the 4.3 votec try auto zone, they have robertshaw t-stats for around 10&#036; for your app. i think.
    yeah lets all take a laugh at the funny man with the 4.3. ............... haha no im just kidding. so wait a lower number in temp like the 160 is better then a 195? so does that mean when it hits 195 degrees what happens? or how does it work?
