Long time lurker here; first post. I've studied this swap for about a year now and recently acquired a 2012 L94 6.2L with 5 miles on it. The 6L80 is out of an identically optioned 2012 Denali; it has 10K for mileage. The engine swap won't happen till probably March. I'm hoping to get most of the parts on hand and knowledge in my head before then. I'm hoping the swap itself won't take more than a month. (This won't be my first engine swap, but it will be my first LS swap.) My plan is to keep the motor and trans as close to stock as possible. My intent is to keep the BCM in the mix for cruise and "tow" mode.
I've owned the '92 since it was 6 months old. It's in pretty darned good shape, but the tranny is getting tired. I've already swapped in a freshly built 14 bolt SF rear end with an Eaton Trutrac. 3.73 gears. Once the engine swap is done, I'll redo the interior--although Infiniti G37 seats are going in this fall, before the engine swap--then I'll re-paint to finish it off.
My first question regards the 6L80. I understand it's about an inch shorter than the 700R4. I know most folks use 1" setback mounts to get the trans in the right place, but that won't be enough here. Is there enough room to put the motor far enough back to use stock driveshafts? If not, what setback is a good compromise for access to the rear of the engine? (I'll be using electric fans.) Also, has anyone dropped a LS motor with a 6L80 already attached into an OBS truck like this? If it fits easy enough, that seems like it would be a lot easier than getting the trans in place afterwards...
Thanks in advance for any and all advice!
