Thank you in advance for any help, it is much appreciated.
I am swapping a 2006 LQ9 into my 1989 V2500 Suburban and I am going to make it CA smog legal, which complicates things a little. Member Kewljay has advised me to try to swap a newer fuel tank into the 89 so I can take advantage of the evap emissions components already in place. After researching it looks like I could use a tank from a 99 suburban and make it fit. 99 looks like the last year that they mounted the tank in the same position as my 89... behind the rear axle, in between the frame rails and it has close enough dimensions that I think I can make it fit. The 99 sending unit will have the pressure sensor and tank level sensor incorporated into it which I need for the evap system. Because I will be using components from 3 different years... 89, 99, and 06, it isn't as straight forward to me to make it all work together so I have a few questions that I haven't been able to answer.
1. Will the stock 99 sending unit/in-tank fuel pump provide enough fuel pressure for the LQ9?
2. Kewljay brought the ORVR valve to my attention, does anyone know if I will need one in this application? I have researched but can't find a definite answer. If I do need one, I cannot seem to find one, or find where it would go, or find anyone who even knows anything about it. I believe it would need to be somewhere in the filler neck or tank inlet. I cant even find where I could buy one to try to add it to the 99 tank, since I don't think they were required in 99.
3. The 99 fuel tank has three holes/inlets/outlets on the top of the tank. one large hole for the sending unit, and two smaller holes. One of the smaller holes is for the vent valve (I think) and the other??
Again thank you to anyone that can help and thanks Kewljay for the help you already provided (if you read this). Also, if anyone thinks of something that might be a problem with this setup please let me know. Thanks!
