Results 1 to 10 of 31
Thread: Inline fuel pump placement
    Ponca City
    In the 2000 silvy I got a fuel cell from db rods and fits nicely. Where are guys putting thier inline pump? My pumps the eliminator a1000, so it's not the smallest pump.. I still have leafs and don't have room to mount it right there next to the cell.. I'd like it as close and low as possible. I had it mounted on the frame in front of the axle but seems to have issues picking up fuel...granted the line from tank is prolly 6 feet long...not ideal.... Thoughts, ideas, pics? Thanks!
    Slowest in Oklahoma...
    Pittsburgh, PA
    any setup ive played with that had a cell and external pump, the pump was always right next to tank and lower then the drain fitting. im aware on a truck this is hard to make possible
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Shawn are you friends with Ryan on fb? The Ryan with the black and orange obs that runs 9s? He made a bracket for his... like a crossmember.
    heres mine and it works well without issues
    Simple: 408 on steroids!
    single digits coming soon!
    Round Rock, TX
    If you could mount it behind the tank hanging down it would be ideal. Get it as close to the bottom of the tank as possible. Definitely sounds like its a little high.
    Ponca City
    I have leafs running along the outside of the frame though David.. It's hard to have it lower than cell cause of how low the cell and truck set..
    Round Rock, TX
    Can you mount the pump off one of the fuel cell mounts. Maybe make a plate that can bolt to one of the mounting tabs on the cell. Almost right where the hose clamp is at in your pic? I thought you had a Magnafuel pump? They usually will bolt right up with the supplied bracket.
    Round Rock, TX
    Pretty much in this position.
    Ponca City
    When we where talking about it I did. Hooked it up and it didn't work right outa the box. So sent it back and said the hell with that. Lol That pic has the pump a little bit higher than the bottom of the tank, would that be ok? I'm pretty sure that's my tank/pics you had sent me when we where talking about it. Ha
    Round Rock, TX
    I thought those were yours but couldn't remember. Yeah that pump placement is fine. Even a inch or two higher would still be ok. Just be sure to keep at least a 1/4 tank when doing wot pulls to be safe.
