Results 1 to 10 of 18
Thread: walbro going bad??
    Feb 2010
    Odessa, texas
    walbro going bad??
    Anybody had a walbro go out after 2 months? Well I think mine is going out. After its started and driving about 5 minutes the pump will start to whine and it will act like its running out of gas. Sometimes it will die and will take 1-2 minutes to stop whining and work correctly
    1983 Ford Ranger- 2.3 to 205k mile 6.0 swap
    Quote Originally Posted by danger_ranger83 View Post
    Have you replaced the filter? I know we discussed this before. Filter issues and what not. It may be sucking up trash and getting clogged.
    Feb 2010
    Odessa, texas
    Yea did all that today and that's when it started dying and stuff before it was just a noise. Now it dies and runs like crap.
    Possibly debris bypassed the filter? What about the voltage to the pump? What's the voltage look like? Hell it's possible that it's a bad pump, you just don't hear of many Walbro failures that soon.
    Feb 2010
    Odessa, texas
    I'm not sure about the voltage. Its worked fine until now? Ill check it tomorrow and if its fine I have no idea what's going on. If its a bad pump I wonder if they will warranty it? Prolly not
    Dec 2008
    san antonio TX
    what kind of filter are you using, a vette filter/reg? my walbro intank pump whines also. is it normal?
    Feb 2010
    Odessa, texas
    I'm just using the sock filter and a regular inline filter too. It whined before but not near as bad. I can't hear the truck running at idle over the pump.
    Dec 2008
    san antonio TX
    man that must be loud.you might want to call walbro or where ever you bought it. i did when i was having problems, they walked me through some steps and they sent me a new pump. not sure if you have a intank or inline pump you think you might have a ground issue just a guess.
    Feb 2010
    Odessa, texas
    Its an intank pump that I got from summit
    Dec 2008
    san antonio TX
    i bought my pump from summit also. give them a call they will send you a new one. they took care of me, probaly because i bought lots of stuff in the past. check if you have a good ground, good voltage, filter, reg, fuel line in the tank, get a fuel pressure gauge on the rail to see how much fp you have, wonder how much it has when it starts missing.
