Hey guys brand new here thought i would share my build info with you guys. I put a carb'd 6.0 with L92 heads and a comp cam in my '91 s10. It started as a low mileage junk yard shortblock. I put in a XR281HR comp cam,ARP rod bolts,ARP head bolts, HD LS3 timing chain and some Pac 1218 beehives. Then topped it off with an L92 Victor Jr. intake and a Proform 750 DP. The trans is a th350 with a 3400 stall and the rear end is a disc brake ford 8.8 with 373 gears and a posi. It puts out about 550 crank shaft HP. The truck will smolder the tires off at freeway speeds. This thing is fun!
