Results 1 to 10 of 15
Thread: Cool Idea
    Sep 2010
    McPherson KS
    Cool Idea
    Was looking into some tranny build parts when I stumbled upon this http://www.transmissioncenter.net/_DSC2612.JPG It seems like a pretty cool idea that should work well.
    Does water just flow through it?
    Broken Bow, OK
    Air
    Sep 2010
    McPherson KS
    Yeah, I guess it just sits a bit lower than stock and air flows through the tubes in the bottom. They say it will drop temps from 20-50 degrees. Wonder if you could replace an auxiliary tranny cooler with this
    Nov 2009
    chicago, il
    Are fins not good enough any more?
    GET OUT OF HERE WITH THAT RICER MATH!
    If you aren't living on the edge, you're taking up too much space.
    Sep 2010
    McPherson KS
    of course not! We must over engineer!
    looks like mud and other road gunk would end up clogging it up... and god forbid if you hit then ran over some small animal....
    Plainfield, IL
    This has been on my list for a while... had one on my camaro LOVED IT. Makes a pretty big difference on the temps, maybe not 20-50*...atleast 15-20 though. Even if it does get mud/dirt in it, just make sure you hose it out every once in a while. I know they make steel and aluminum...i feel aluminum is less likely to rust.
    Broken Bow, OK
    Quote Originally Posted by oleshifty View Post
    I'd say so, yeah....lol.
    Houston
    will the tubes still cool properly if im racing in reverse?
