Results 1 to 10 of 16
Thread: Window switch?
    Nov 2009
    Tucson,AZ
    Window switch?
    I have a cold fusion plate kit, it says good up to a 250 shot. I want to run a 100 shot to begin my experience with nitrous. I'm going to do a walbro 255 in the tank. Im goi g to be mixing race fuel 50/50 until i get my tune set up for the nitrous. And I'm wondering what window switch I should get? Should I get a rpm switch and a window switch?
    chevyboy.520
    06 ecsb 5.3, FAST LsxRT 102, FTI cam! LT's, tru dual, magnaflow, 3400 stall, Performabuilt lvl2, 4.10s!
    PRC stg 2.5 5.3 heads Awaiting to go on!
    i got a brand new window switch still the plastic box if interested, its from nitrous outlet, i was gonna use it but decided on the button instead
    Simple: 408 on steroids!
    single digits coming soon!
    Nov 2009
    Tucson,AZ
    How much for it?
    chevyboy.520
    Quote Originally Posted by chevyboy.520 View Post
    How much for it?
    i'll send ya a pm about it first thing tomorrow, still at work
    Nov 2009
    Tucson,AZ
    Is the window switch all I need? What else is there?
    chevyboy.520
    Nov 2009
    Tucson,AZ
    Quote Originally Posted by skeet View Post
    thanks!
    chevyboy.520
    Nov 2009
    Tucson,AZ
    How is everyone hooking up there rpm switch or window switch? And pix?
    chevyboy.520
    Plainfield, IL
    Was going to start a thread...but this is about same thing. Is there a way to do a window switch just for 2nd gear? With my gear, first goes too fast, and I know I'll spin tires if I spray. Just want to spray when I hit 2nd, and stop before it shifts. What brands is everyone using? How do you get the rpm signal to the switch? We can't tap off coil like old school cars can we?
    Mar 2007
    Newark, Delaware
    Subscribed! I'll be needing this info soon.
    Plainfield, IL
    completely off topic.... have you towed with that 3k stall? We have pretty similar setups, would you recommend higher/lower? I was thinking 2800 for mine.
