So I'm shopping for a CAI for my 08's GMC 2500.....any suggestions over one manufacturer or another? I'm staying away from the polished tube intakes.
ill check and see if its the same, but i have a K&N kit that came off my old truck that ill sell you
01 Silverado
Its the same Mitch.
Volant and K & N are the better ones out there
Spectre will save you $200.... got mine for 105.
04 Silverado Z-71 Extended Cab
Magnaflow, 10.4 TV 50 wires, tr-55ix, Synthetics, HID's, JL audio, 33.5", leveling kit, tuned, CAI, vette servo, cam, valve job, pacesetter. 9.3@77.5 and 14.5@93.4
06 2wd
custom cam, tune, 3.73's, servo, HID's, 10.4mm wires, long-tubes, CAI, magnaflow, 2.5" shackles, Circle-D 3200, UD, JL Audio 4.1, Alpine 5ch
the P/N for my intake is -- 63-3058
the P/N for what he needs, 2008 2500HD 6.0 is -- 63-3067
is that right or did i do something wrong?
01 Silverado
What do you want for the K&N? I'll check to see if it will fit for myself, I think I know someone with a denali w/ a CAI i can try out.
Spectre is like 70 bucks. It just needs 4" cut off the tube.
Where can I find a Spectre for $70? I might just fab and insulate my own...poly tubing and a heat gun can work wonders....
Look on Ebay. You can find all sorts of CAI for cheap. Then replace the cheap filter when it is used up.
2014 GMC Sierra Crew Cab
-5.3
-Gibson Exhaust
Spectre can be found on Ebay or if you know someone at a parts store that gets a store discount you can get one there.
