Results 1 to 10 of 14
Thread: trans temp
    Nov 2009
    trans temp
    so i installed a new trans temp gauge todat before i did a bit of driving around and realized i have no idea what optimum trans temp should be. driving on the freeway i stayed at about 180 but driving around town i went between 200-220 . so what temp should i be around?
    Today 03:25 am 6 stringer o thats a good point, its ok ill just add a blinker fluid cooler
    Today 03:24 AMtruckinL33 that's not a good place for it, you can overheat your blinker fluid with the capacitor
    Today 03:23 AMtruckinL33 i need them for when i go back to 1985
    Today 03:23 AM6stringer i mounted my flux capacitor next to my blinker fluid resevoir
    Today 03:22 AMtruckinL33 me too, right next to my flux compasator!
    Today 03:22 AM6stringer hey gear oil needs to be cooled, i have front and rear diff coolers
    Feb 2009
    Houston
    Quote Originally Posted by 6stringer View Post
    Thats too hot man. I believe the sweet spot is 160. 200-220 is too hot! mines only gets like that after i really get on it alot
    Feb 2010
    that's 2 hot.. X-2
    at 220* i smell burned clucthes
    get a tru-cool 40k tranny cooler..
    Nov 2009
    well i bought a 12x9x3/4 12k gvw tranny cooler too i just havent installed it. now i know why my trans died in less then 30k. why would it overheat like that? and i guess partially i can thank gm for there awesome design flaw. lets put a cooler that likes to be around 160 in a radiator that hangs around 210. outstanding
    Broken Bow, OK
    What kind of gauge did you install and where is the sensor? Makes a big difference.
    Nov 2009
    its a autolite and i installed the sensor in the plug just behind the bell housing on the driver side. i saw it in another thread
    http://www.ls1truck.com/forums/sale-...emp-gauge.html
    Mar 2007
    I got mine installed in the same spot, and compared to HP tuners inside temp sensor readings was 1 degree of to the cooler side always, so not a biggy.
    Mine is Cyberdyne Digital.
    Apr 2011
    nobody mentions the part Number so I thought I Would. Its an autometer #4357-
    Mar 2011
    San Antonio
    I also have the same gauge same spot you connected yours. I got the biggest b&m trans cooler by past the radiator,temp stays 180 in summer a/c blasting in 100 degree weather. San Anto Tejas
    2000*GMC longtubes nelson tune, built trans,trutrac circle d 278 mm stall 373 posi,100 shot of dope and 228 232 588 595 cam.
    Sep 2010
    McPherson KS
    Glad to see mine is not being abnormal. It will occasionally hit 200 if I'm going down the highway and on a hilly stretch (try and have someone tell you kansas is flat) but usually hangs out around 175 or so.
