Results 1 to 10 of 11
Thread: TR220 what lobe separation you running
    I know the TR220 is a killer cam for the 5.3 what lobe separation are you guys running on this cam ?
    Dec 2008
    Sherman, Texas
    I run a 114 in my 4.8 i like it alot
    02 Fully forged Iron Ls1 233/239 595/603 112lsa,
    milled, ported& polished heads,
    K&N CAI, shorty headers,
    off road x-pipe, Pypes M-80s dumped,
    TCI 3600 stall ,TransGo shift kit,
    True Trac w/3:73s, 4/6 drop,
    and a Fast LSXRT 102
    Oct 2005
    drinking your alcohol
    i ran a 112 on mine....
    this is my old cam... i have the 228 now
    2002 Silverado 5.3 Long Tube Pace Setters, and a - Car Videos on StreetFire
    DamnYankee: my nana failed
    Quote Originally Posted by Razgriz1 View Post
    No converter with that in a 4.8 ? hows your low end ?
    Dec 2009
    Houston, TX
    Soon to be running the TR220-112. I wound up choosing 112 to let my heavy Tahoe keep its low end (hopefully) and keep the powerband lower for my daily driver.
    2006 Z71 Tahoe - Silver Birch Metallic
    GO: Wheatley 93 street tune, TR220-112 cam, PAC 1218 springs, Comp rocker trunions, U/D pulley, LS2 timing chain, JBA headers, cat delete, Magnaflow catback, AEM CAI, 180º stat, ported TB, Circle D 3200, TransGo HD2, billet servos, Tru-Cool 40K, LS6 valley cover, and many more...
    SHOW: Ford keys, 2" spacers, Bilstein 5100, SS cluster, HIDs, LEDs, and many more...
    Dec 2008
    Sherman, Texas
    not too bad but not great without a stall it is lacking
    Feb 2010
    112 . .. . .
    Jul 2009
    114... no difference you can feel between it and 112 on low end. they got graph of tr224 with 112, 114, and 116... not but like width of dyno line difference
    04 Silverado Z-71 Extended Cab
    Magnaflow, 10.4 TV 50 wires, tr-55ix, Synthetics, HID's, JL audio, 33.5", leveling kit, tuned, CAI, vette servo, cam, valve job, pacesetter. 9.3@77.5 and 14.5@93.4
    06 2wd
    custom cam, tune, 3.73's, servo, HID's, 10.4mm wires, long-tubes, CAI, magnaflow, 2.5" shackles, Circle-D 3200, UD, JL Audio 4.1, Alpine 5ch
    Feb 2010
    220 on a 5.3 is not a overkill. its the perfect cam...
    Nov 2009
    Tucson,AZ
    I run a split duration cam, 218/224 .605/.595 lifts and 111lsa, no noticeable lose of bottom end, but I have 4.10s and a 3K stall mid range is fun to drive in! But the top end gain is the best part! The rush of ripping past ppl at 6500rpms is tight! Also the idle sounds nasty
    chevyboy.520
    06 ecsb 5.3, FAST LsxRT 102, FTI cam! LT's, tru dual, magnaflow, 3400 stall, Performabuilt lvl2, 4.10s!
    PRC stg 2.5 5.3 heads Awaiting to go on!
