S6301642.flv video by tara72689 - Photobucket
Recently put in a 229/229 .638/.640 114.5lsa cam in the motor for gigglez. Wanted a good top end Screamer. The First vid^ is when the motor is first cranked before it is warmed up. Sounds decent aside from the idle rpm is way high being its untuned
S6301644.flv video by tara72689 - Photobucket
^ this is what the truck sounds like after a few minutes. Once the oil thins out from heat maybe?? Sounds like a lifter to me gone BADDDD. I have checked plug, plug wire, rechecked torque on the rocker arms, etc. It sounds bad enough to cause motor issues to me. Its only on the drivers side and if I drive the truck for awhile it will quite down a LIL bit and even to the point it will be silent at idle. But will start making noise at 2k plus... ANY ideas?? How harmful is what Im hearing? Opinions?
