Results 1 to 10 of 16
Thread: 5.3 vs 6.0 intake manifold?
    May 2003
    Idabel, OK
    Question 5.3 vs 6.0 intake manifold?
    Is there a difference between the Vortec manifolds on 4.8, 5.3, 6.0, etc..? Or. Are all Vortec manifolds the same?
    99 C5 cam/boltons 400rwhp
    10 Sierra CC 6.2
    03 Suburban 5.3
    Feb 2009
    Houston
    They are interchangeable.
    Just depends what year it is if its returnless or not.<----(not too sure)
    Nov 2006
    Mesquite, TX
    there is no difference what so ever in the way they flow from 99-07...later models 07-current have a 90mm tb and flow a lot better
    May 2003
    Idabel, OK
    OK, thats what I was looking for. I just didn't know if the 6.0l flowed better than say the 5.3l.
    mean05: You sayin there may be some potential increase in HP/TQ by swaaping to a 07+?
    Thanks for the quick replies
    Eric
    10 Sierra CC 6.2
    03 Suburban 5.3
    Broken Bow, OK
    Will the 99-03 return style fuel rail fit on the 07+ 5.3L intake?
    Quote Originally Posted by stngh8r View Post
    ...You sayin there may be some potential increase in HP/TQ by swaaping to a 07+?
    There is potential, but it is going to be minimal. I would rather spend my time and money on a FAST setup...
    Quote Originally Posted by PitchBlackC3 View Post
    I wouldn't think so. I am not sure if anyone has tried to do that type of swap, but it may be possible.
    Eric
    i got port and polished stock heads, and switched to the TBSS 90mm intake and shaved over a half second on my 1/4 mile times, on motor. maybe that'll help with your decision.
    Pittsburgh, PA
    the work done to the heads gave you the most of that gain
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Nov 2006
    Mesquite, TX
    Eric
    there is a small gain...some have said in the 10rwhp gain, i did the swap on my stock 6.0 and if i were to do it again i'd just go with a car intake...looks some much cleaner
    Broken Bow, OK
    Quote Originally Posted by mean05 View Post
    Did you use your stock fuel rail or have to use one that came with the intake?
    If your 05-rail worked the 99-03 rail should fit too.
