Which one is better and will a 1pc hold up to the 400+hp/Tq I am making. I also run slicks at the track so not looking to wipe everything out. The one i am looking at is a 1 pc 4in aluminum. Thanks gang.
I was always told the 2 piece ones are better for lifted vehicles because of the ability to moderate the angle between trans and rear.
As far as racing goes, i would assume a 1 piece would be stronger/less rotating mass. Most race cars use a carbon fiber or aluminum 1 piece, so there must be a reason.
You ARE extended cab so that is a pretty long 1 piece, might want to talk to the company making the shaft to see what they recommend.
That is what i always thought. I have a drive line vibration that i am looking to get rid of. Seems like the one piece would be better for that but I dont want to toast the trans and rearend if the driveshaft lets go when i launch or going 120+
stay with the factory 2 pc. i used a one pc. and broke it, it was alluminum at WOT the shaft would flex, so after flexing alot lol it twisted and broke.. i then went back to my 2 pc. and ran ever since until i swapped the drivetrain
by the way the 2 pc got me my 11.8 pass![]()
Simple: 408 on steroids!
single digits coming soon!
Gotcha guys Thanks
hey mark what speeds you getting vibration at? might think about pulling the drive shaft with carrier bearing and getting the whole thing rebalanced ?
Check pinion angle if you're lowered. Check carrier bearing/u joints for play
how low are ya, IIRC its like -3 to -6
when i welded my bracket backet back in i adjusted for the pinion angle though
