Results 1 to 10 of 11
Thread: wiring help
    Hope Mills, NC
    wiring help
    ok i kno i posted this in the wrong section. i did it on purpose as this one gets more traffic. I need to know which wire is the signal wire in the oxygen sensor for hooking up an air/fuel gauge? also, which wire in the dash do i jump off of so my aftermarket gauges light up automatically when my headlights come on? thanks!!!
    2005 GMC RST *sold
    2006 Silverado SS with nawz
    Cedar Park, TX
    Quote Originally Posted by turbo4.8 View Post
    if im reading this right, Hayne's says that there is a white wire coming from the ambient light sensor and BCM that runs to the headlamp relay. or you could buy your own relay and wire it up to your head lights. that might be easier
    R.I.P Blue '02
    '08 - 5.3
    Vette Servo, Flowmaster 40
    Cromwell, CT
    For the signal its the high side 02 blue connecter on pcm pin 66 for left or 69 for right
    01 ecsb 5.3 4x4 z71
    Avalanche 17s and a pant load of miles
    61 Corvette
    350, 4 speed, 4.56's
    32 Ford 4 door sedan
    keeping it "stockish"
    Cromwell, CT
    you don't need a relay for the lights, you can hook the light up th the red wire on the back of the cluster or if you have an aftermarket radio you can take power form the illumination wire now your gauge will dim with the rest of the dash
    01 ecsb 5.3 4x4 z71
    61 Corvette
    Hope Mills, NC
    ok got it all wired up this morning and have it all working. only thing is, my air/fuel gauge is really jumpy back and forth back and forth. even at idle. Do you think my factory tune is that off? or do i not have a really good connection where i tapped into the signal wire? went to pin #69 blue. engine light is on also. im gonna scan it this afternoon and see if that has anything to do with it. any ideas?
    2005 GMC RST *sold
    The AFR is always like that. It refreshes that fast.
    Hope Mills, NC
    engine light had nothing to do with it. cleared it and it all went away. afr is still really jumpy. idk seems odd to me. but i guess thats how its supposed to be?
    2005 GMC RST *sold
    Aug 2005
    St. Anthony, Indiana
    well it sounds like you hooked up a narrow band a/f gauge, which is a waste of money. If you want to know your a/f ratio you need to get a wideband setup.
    Cromwell, CT
    its normal for it to bounce around, thats how you know its working.
    01 ecsb 5.3 4x4 z71
    61 Corvette
    Hope Mills, NC
    had it lying around for a while so i figured id throw it in there. plan is to get a wideband when i get some casssshflow. just playing with parts i already have. just wanted to make sure its working right.
    2005 GMC RST *sold
