If i put my truck in reverse, and turn the front wheels at all, when I'm backing up my driver rear tire just kinda skips, while the passenger side turns.
SOMETIMES it does it going forward (after backing up)...it's been doing it a couple weeks, but seems to be getting worse. It's tearing up my rear tires. I been on the truck a little, but no more then I have the entire time i've owned it. This rear end came out of a truck in junkyard, has less then 50k on it with a 3.73 g80 locker. old rear was a 3.42 open with 130k miles, never had a problem.
Do you think this is just my g80 and the heavy/large tires, or should i be worried? What should I check first? The inside looks normal to my untrained eye. No play in driveshaft, etc.
