Results 1 to 10 of 11
Thread: Mounting PCM
    Mounting PCM
    Where/how do you all mount the ECM/PCM? Is there a bracket available for under hood mounting?
    Aug 2009
    Quote Originally Posted by Clyde65 View Post
    i was wondering the same thing!!! anyone?
    San Marcos Texas
    The Camaro has a PCM mount that is pretty good. There might be more.
    Gramercy
    01 gmc has a mounting bracket that mounts it on the frame horn, or just make your own mounting bracket
    2008 GMC CCSB 6.2/6L80e swap
    Aug 2006
    I used one off a 2000+ model s10/s15.
    Mounted it on my inner fender, worked out good.
    Check local boneyards or ebay.
    86 C10 6.0/4l80e
    Monett Mo
    I used a mount out of a 97 tahoe and mounted on fenderwell.
    1992 rcsb k1500 lq4 4l80 swap done.If anyone has questions feel free email as I'm not on here very often. bobby_seitz@yahoo.com
    Oct 2009
    I did the same as PCMCOBRA, the S10, PCM mount is a tray with
    a strong snap lock. Mounted my on the inner fender r/side.
    There only about $20.00 from Chevy
    Sep 2006
    THE 405
    I cut my original bracket/holder up and mounted it where the battery used to go
    midweststreetcars.com
    so...are they covered up? or sre they just connected to the tray and plugged in? I dont plan on going mudding or forging through a river so it wont really get wet but moisture will always be around.
    Oct 2009
    No it's an open tray. But the PCM is a sealed unit and mositure
    shouldn't effect it.
    A lot of PCM's that are mount under the hood now days aren't
    covered.
