Keep us informed ,mines been doing it for a year and all i could describe was seems like its hitting the rev limiter ,so i had it raised and it still does it.I almost thought it was a fuel issue,but thats more than adequate.It acts like its hitting rev limit ,stutters at high boost then shifts when i let up or stutters into the next gear.Nelson will call he just has a huge work load.
