Results 1 to 10 of 13
Thread: AEM boost controller/gauge
    wichita falls, tx
    Has any one heard anything about this it looks like its a really cool design because it fits into a normal gauge pod but i dont know anything about it or how
    easy or hard it is to put in
    heres the link
    AEM - TRU-BOOST Gauge-Type Controller
    Junkyard 5.3 milled heads 200 shot, built 4l80e with circle D 4000 multi disc converter
    EPS cam 23x/23x 600/603 112lsa
    KP 6 link bagged with Accuair E-Level
    http://www.nitrousexpress.com/
    Oct 2008
    Houston
    Seen one on turbo Mustang before.
    Worked like a charm. Push a button for more boost.
    You run the lowest boost level you want for a spring in your wastegate.
    Then the controlled valve will let you control vacuum to the wastegate to go higher from there.
    2002 Tahoe 4.8 - soon to be turbo'd - SOLD
    1989 Mustang - LX Vert - 351W-TT - 2inches of dust covering it
    2012 Raptor - 497rwhp at 10psi
    If you aint breaking - you aint going fast enough
    wichita falls, tx
    so u think it is worth the money
    Curious... . . I want to know more as well. I could use one for sure.
    Nov 2006
    Mesquite, TX
    I havent heard a lot about this controller....i went with what i know people are saying praises about which is the turbosmart eboost2 boost controller...should be here later this week
    wichita falls, tx
    Yeah I read about that one the only thing that I really like about the AEM one is that it fits into the 2 1/16th gauge hole which the turbo smart one is 60mm which is to big
    Nov 2006
    Mesquite, TX
    Quote Originally Posted by dropem View Post
    Guess you arent used to making holes bigger
    Feb 2009
    Wichita Falls, TX
    Ive heard both good and bad...
    Alex
    02 Chevy RCSB V6 -> H/C 5.3L SOLD
    03 GMC RCSB 5.3L CAI,Tune,3/6 drop
    Birmingham, AL
    bringin this back, anyone know any more about this controller now?
    01 Silverado
    Feb 2009
    Wichita Falls, TX
    Ive read up on them and asked some buddies what they thought... all in all they said its alright, but since the run off the voltage of the battery they said there isn't an exact accurate reading due to the voltage constantly changing... idk plus there is some other boost controllers out there that will drop boost levels if it feels the tranny slipping and whatnot, idk if its true just what ive heard.
    Hope that helps some
    Alex
