Sup guys I just bought a 98 S10 Blazer with the 4.3 v6. Which stalls out when I give it gas when its in first. A slow accelration it wont do it. But if I floor it it cuts out and chokes on me. Or if I try to foot brake it and give it gas it chokes and dies. I have a code its a PO420 which is catalyst efficiency low-bank 1. So what i want to know is it the cat or somehting else cause at AZ the code causes were the cat, engine misfire or running condition, Large vacuum leak, and the big one engine oil leakage into exhuast valve guide seals. piston rings. The truck also has a bad valve tic. So what you guys think? Go down the list fixing things. HELP!!! Thanks
