Results 1 to 10 of 12
Thread: Intake idea
    SE Georgia
    Intake idea
    What do you guys think about this idea for my intake?
    This is the filter I would put on it...
    K&N RF-1034
    Tired ol' 5.7, 5.3 swap in progress
    Handle every stressful situation like a dog.
    If you can't eat it or hump it.
    Piss on it and walk away.
    Okeechobee, Fl
    I once asked the same ? and everybody said all it would do is suck hot air and I would lose HP.
    49 Ford F1
    Apr 2006
    Bellevue, Nebraska
    I've always had the idea of getting a vette or Camaro SS style intake and making a functional ram air, Just never had the time or money to do it.
    too much hot air right there
    SE Georgia
    I cant see where it would get that much less hot air if I moved it a foot and a half to the left or right..
    May 2004
    You'll pick up heat anywhere under the hood. You get air through the passenger side fender so if you 90 it and remove the plastic plenum from the core supportt it will get cool air while moving. There's no good place under the hood except for the factory box that kept cool air sucking in all of the time but took HP away.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    SE Georgia
    So other than it sucking hot air it should be fine?
    May 2004
    You don't want the filter directly in front of the fans though. You might get into some knock retard so I wouldn't keep it there forever if you're looking for efficiency.
    97 GMC, 2002 LS6.
    I had my air filter just like yours but lower(LS1/LS6 intake) and when it was on the dyno the air temp was in the 130's.
    When I put a K&N 8.1 truck elbow on it the filter sits where the storage box was and I gained 30RWHP!
    1997 GMC RCSB
    LS6/T56
    San Antonio, TX
    Temporarily, it's ok.
    However, during traffic and city driving, your power loss will be significant.
    The pcm has a table that modifies timing based on iat, on some trucks, 15degs of timing gets pulled, that's more than half the applied timing at wot!
    Timing makes power.
