engine bracket questions for OBS 5.3 install
I ordered the LSX conversion plate from ebay that lets us OBS guys bolt the 5.3 into an OBS truck. Heres my question. I went to install the motor and the oil pan is hitting the cross member on the passenger side and not going down far enough to bolt in the mount. on the driver side the exhaust manifold is hung up on the upper control arm mount. Now heres my question.
for those of you familiar with the plate adapter that gets bolted to the mount I have the mount setup so that the OBS bracket that gets bolted to that adapter is further back on the plate (closer to back of the motor). If I were to flip them around would that solve my problem? or do I need a different oil pan for this application? I am thinking I just have the adapters on backwards but thought I would ask...
Josh
- You may not post replies
- You may not edit your posts
