Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 54
Thread: list for cam install
    Southeastern Wisconsin
    Well i ordered most of the stuff i need i think just need to make sure i am going to have everything i need for the install.
    Heres what i got on the list so far:
    Spark Plugs
    Timing Chain
    Cam
    Valve Springs
    Retainers
    Valve Spring Tool
    Lifter Tool
    Timing Cover Gasket
    Water Pump Gasket
    Headers and flanges
    Re-Tune
    Valve Cover Gaskets
    Pulley Puller (gonna rent this)
    Anything else anyone can think of?
    ff_jeff Guest
    underdrive pullies, Efans, Might throw on a shift kit and servos for the tranny while your at it.
    Mar 2006
    Mesquite
    Quote Originally Posted by 99sierra4x4 View Post
    Spark Plugs
    Timing Chain
    Cam
    Valve Springs
    Retainers
    Valve Spring Tool
    Lifter Tool
    Timing Cover Gasket
    Water Pump Gasket
    Headers and flanges
    Re-Tune
    Valve Cover Gaskets
    Now would be the time to spring for an underdrive pulley. But either way, you'll need a new crank bolt ($10 or so at dealer). Use the old crank bolt to put the pulley back on, then back off the old bolt and put the new one in. Use an impact wrench to remove the old crank bolt - if you torque on it with a breaker bar, you can snap the head off. Use the impact wrench to tighten down the new bolt. There's a torque sequence for it but tightening it with the impact will be fine.
    You don't need a new water pump gasket or timing cover gasket - they're reusable. Doesn't hurt to replace them though if you already ordered them. If the old ones look ok I would return the new ones or try to sell them.
    The valve cover gaskets are built into the valve covers - they don't need to be replaced.
    You should without question add hardened pushrods while you're in there.
    i already have E-fans on there and a Nelson harness. The undrive pulleys ill do another day im basically at my budget limit for this string of mods.
    Ok i wont change the gaskets on the timing cover or the valve covers.
    I will get a new crank bolt, and the cam kit comes with hardn'd pushrods as well.
    what size cam are you going with again?
    Thunder Racing 220/220 .551/.551 114 LSA
    also picked up some ceramic coated Pacesetter Lt's
    Also the patriot dual golds, hardened chromemoly pushrods, titanium retainers.
    Also picked up a brand new LS2 timing chain for 60 shipped
    oh yeah thats a great cam. thatll work out real well. Who are you gonna get the live tune from?
    well right now i have a wheatley tune and im gonna wait to see if he is going to email me back. If he doesnt get back to me im gonna call nelsonperformace up and have them do a mail order for me and rush ship it so it is here in time for the swap. I only have a weekend to do it.
    Other than that i think i almost have everything i need!
    i cant wait.
    1999 GMC Sierra SLE ECSB .... 5.3L w/ Slight Performance Tune / True Duals with Flo Pro Glass Packs.
    Project ''Bad Company'' Future = 6.0L (Forged Internals) / Boost (TVS) / 4L65E LvL 5 / AWD Conversion / Full LT's with Cats / Methanol Injection / Lowered 2" / SS Rims / Frame Up resto
    Officially Employed!!!
    Hutto TX
    Couldn't hurt to have some spare valve retainer locks handy....tiny little beestards.
    1991 Silverado ECLB
    LM7-T56
    i cant wait.
    Might as well go ahead and call nelson...
