Results 1 to 10 of 15
Thread: Cam install
    have any of you done a cam swap without new springs? and if so how big was the cam?
    its just a work truck 4.8L with a 5 speed
    Oct 2005
    drinking your alcohol
    i havent heard of any personally.... IMO i would just spend the lil extra cash for ALOT of security
    DamnYankee: my nana failed
    Dec 2003
    Newark, Tx.
    pretty much, any cam change should get better springs
    Apr 2003
    Mansfield, Texas, USA
    Cool
    Pick up some yellow LS6 springs, good to right around .550-.560" lift. Best part, under $75.
    Aug 2005
    Houston,Texas
    I suggest springs on any cam, I was floating valves with my 02 LS6 cam which is a baby cam 204/217
    99 ECSB 5.3 LS6 CAM AND SOME BOLT-ONS BEST TIME 13.6@97MPH
    http://i104.photobucket.com/albums/m...wTRUCKS008.jpg
    May 2007
    i have a simular question. i just got done installing a vhp .551/.551 "the trucker cam" and i installed with stock valve springs.... now the cam is supose to only have power until 6200, will i start floating them way before that??? i know with the stock didnt float the valves until around 6000 so i wouldnt think that 200 extra would be to bad. i dont even know if im gonna have it shift that high. but anyways just curious.. thanks
    ryan
    -04 reg cab shrt bed
    -5.3l
    -best 12.6@106
    You're going to beat those stock springs to pieces. If anything I'd lower the redline to prevent floating the valves. The stock springs weren't designed to handle those rpm and you've increase the speed and ramp angles of the valves along with the distance they'll have to travel. Did you also reuse the stock pushrods?
    May 2007
    yes i did use the stock push rod i really dont want to pull this thing apart again.. i figure the worse that happens i that it will float them. it sucks having put the motor all together and then find out that i gotta take it back apart
    ryan
    -5.3l
    -best 12.6@106
    Mar 2006
    Mesquite
    research people research!
    all you have to do is pull the coils and valve covers to switch springs and pushrods. Get some CompCams 26918-16 springs and 7.400 CompCams or ThunderRacing hardened .080" wall pushrods. There's a guy on LS1Tech in the tool section that markets an inexpensive spring compressor tool, about $20. An air compressor tool to hold the valves and you're ready to switch springs. I'll take the spark plug out, put some cotton rope into the cylinder(leaving some hanging out to retrieve it) and the rotate the piston around to TDC to lock the valve in place while swapping springs.
