<div class='quotetop'>QUOTE(SCIV @ Feb 23 2007, 11:07 PM) [snapback]84328[/snapback]</div>
My harness crapped out. It has been burning up relays since I got it, they would normally last about 6 months. Now the fan won't cycle with AC, so I replaced the relays and nothing. I took all 3 relays out and put one old one back in and it worked. Then turned the truck off, restarted it, and it won't work again. Took the relay out, put it back in, and it worked again. Then turned off the truck, and the fan kept running??? I had to pull the relay.
Can someone post a diagram so I can wire a relay in to be switched on with switched power. I don't care if the single fan runs constantly or not, at least it will run. I can use one of the relays that is still working and steal wiring from the harness. The truck doesn't overheat, but the AC wont' work when this is happening.
This is for an '04 with '05 efans and Nelson Harness.
Thanks guys,
S.C.
PS - I am going to bed now, so I can answer any questions until the morning.
![:yawn:](http://www.ls1truck.com/forums/images/smilies/icon_yawn.gif)
Hey don't feel bad, your not the only one with a defective harness, my fans cycle every five seconds and i have gone through 3 105A alternators and finally stepped it up to the 145A alternator and still having problems.
Good Luck
06 TrailBlazer SS LS2 4.10's
02 SC StepSide Factory Orange
Full Bolt-On 370 - Little Cam- Victor Jr Intake -Worked 5.3 Heads - 4.56's - Built 60E - Circle D 4000
07 CTS-V CAI, GM Performance Exhaust, Ported TB, Coil Overs
