Results 1 to 10 of 14
Thread: "Oh Sh!t" handle removal
    Has anyone ever removed the "oh sh!t" handle just above the passenger side airbag?
    If so how do I do it?
    Birmingham, AL
    sawzall.....
    01 Silverado
    Broken Bow, OK
    pop out the AC vents to the left and the right of it.
    Reach inside and there is a release you press while pulling out on the handle. Have to do both sides at once while pulling out on the handle.
    awesome pitchblack thanks
    yea when you reach in they are up close to the front theyre white you can either push down on em and pull the handle out with your mouth or push down on one side pull it out a little then the other side, being as youve never had it off it may be a PITA at first.
    I called the lil brother to be the "puller"
    Dec 2008
    Sherman, Texas
    yea when you reach in they are up close to the front theyre white you can either push down on em and pull HIS handle out with your mouth or push down on one side pull it out a little then the other side, being as youve never had it off it may be a PITA at first.
    WOW sounding like an expert there
    02 Fully forged Iron Ls1 233/239 595/603 112lsa,
    milled, ported& polished heads,
    K&N CAI, shorty headers,
    off road x-pipe, Pypes M-80s dumped,
    TCI 3600 stall ,TransGo shift kit,
    True Trac w/3:73s, 4/6 drop,
    and a Fast LSXRT 102
    Quote Originally Posted by Razgriz1 View Post
    I knew it would go gay just waiting to see who it would be.
    Dec 2008
    Sherman, Texas
    You know it doesnt take long around here
    when you're known for putting your mouth on it and pulling and doing a two handed reach around, what else needs to be said?
