Results 1 to 10 of 12
Thread: gas requirements for turbo
    I would like to know what every one uses for gas.. Are you guys running boost controller that allows you to turn down the boost for 87 then back up for 91 ?? and or using meth/water injection to control detonation? I'm thinking I will have tuner go with a conservative timing amount regardless.
    Or is there someway to switch between more than one "tune" like we could in the diesel world?? EFI Live even has a rotary switch that you can switch between different tunes (hp levels).. Any thoughts
    2005 GMC Seirra CC SB z-71, Stock for now
    Quote Originally Posted by BigShow1066 View Post
    Big fuel pump, nice size injectors. Running 93 octane all the time, with a meth pump and a single nozzle spraying at/after 2-3lbs..
    Apr 2005
    E85
    Gone, but not forgotten!
    What fuel pump u running David?
    Pittsburgh, PA
    Wanting info on turbos yet uses 87 octane in same topic
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    im not lookin to put down the most horsepower i can... Im just wnating to step it up , make it fun to drive. I'd just like to hear from guys that have experience
    Arizona/Utah
    I would say don't run 87 if you are boosted. Seriously what is the extra 20 cents to you? Running pump 91-93 is a basic thing you should be doing. Minimum to go boosted you will need bigger Fuel pump, and injectors.
    Quote Originally Posted by o2camaross View Post
    walbro 255
    Pittsburgh, PA
    There's plenty of experience
    Spends thousands to save pennies .....doesn't make sense or to risk the motor
    412 Motorsports
    Okeechobee, Fl
    Exactly what he said...
    49 Ford F1
