2004 Silverado Ext Cab LS w/408
Less than 5000 miles on new motor & Trans
New GM 6.0 block .030 over
K1 forged stroker crank (408)
Diamond 10.5:1 pistons
Manley steel h-beam rods
SLP oil pump and timing chain set
ACI Racing rod and main bearings
AFR 205 heads with Comp 918 springs and new valve train
Morel lifters
Comp 231/239 617/624 113 cam
FAST LSXRT intake
FAST billet fuel rails
Torque Rush X-Link module
92mm GM TB
45lb injectors
Walboro 400 Fuel pump and new fuel pump module
ATI Super Damper
ARP fasteners
1 3/4" LTs to full 3" stainless dual exhaust with 23” Magnaflow muffler
Volant CAI
New water pump
Champion Alum radiator
Derale dual electric fans
New fan shroud
Built 4l60e
Yank 2800 converter
One-piece aluminum drive shaft
Eaton posi
373 gears
Baer rotors
New Hawk brake pads
Wilwood master cyl
HydraTech hydra-boost system
Nitto NT420 tires (less than 2000 miles)
Black Enkei M6 20” wheels
Rhino liner & GM bed mat
No major body damage but a few dings and needs paint
Interior is in great condition
New headliner
Pioneer XM ready stereo w/ factory Bose amp & speakers
AEM AFR & Fuel Pressure gauges
Escalade dash
215,000 miles
$15,000 OBO
Clean title in hand
Located in Escondido, CA
More pics and video available
Reason: lower price
- You may not post replies
- You may not edit your posts
