lq4 into OBS swap et?
I'm curious what 1/4 mile et y'all think my truck will run. I'm getting close to finishing the swap so i will find out for sure. for now it is going to be a stock lq4/4l80 swapped into a 1996 chevy 1/2 ton extended cab. i think it will weigh around 4300 lbs, though im not 100% sure. i did search, the subject, but couldnt find aany straigforward answers
I had plans to turbo it, but other obligations are going to delay that. i will probably go ahead and put a cam in it in the near future and spray it till i get into the mid 12s as this seems like the quickest/cheapest way to get there. i think i would be happy with a mid/high 13 in N/A form for now.
- You may not post replies
- You may not edit your posts
