Page 13 of 23 FirstFirst ... 3 11 12 13 14 15 ... LastLast
Results 121 to 130 of 229
Thread: First time swap. LQ9 into 95 OBS
  1. #121
    Aug 2012
    Portland, OR
    Quote Originally Posted by kewljay223 View Post
    hey. glad to hear that all my detail has helped you out. its not easy to find explanations of things cuz a lot of people dont want to take the time to type it all. especially about smog. it SOUNDS like your in the same boat as me from what you said... if your getting the ls1 pan, i assume your truck is dropped also. how much? and based on you wanting the o2 sensors and only a 112 LSA cam, sounds like your tryiing to keep it smog legal.... but i cant see where your from. are you in cali too trying to do a CARB legal swap?
    ill keep an eye for your thread but just in case, post the link here when you get it started. i def want to check it out.
    as for the oil cooler, from what i read, its not really NEEDED as most guys just block it off and they have no problems. but i figured since GM had it factory, and i do plan on pulling a boat in the near future, any extra cooling is benficial. so the extra 100 bucks for the parts was fine with me. plus, who can resist the cool looking braided lines and AN fittings!!!???? haha!!!
    hit me up if you have any quesions. more than glad to help ya out.
    It's dropped 4/6, but I am not doing a CARB legal swap. I'm in Oregon and they just sniff the exhaust without even popping the hood.
    I'll look into the oil cooler a little more, but I am thinking I will add the lines especially if it was just 100 more. Plus I get braided ss hose and AN fittings lol.
    I'll post that link but it won't be for at least another month. I am graduating next month and am swamped with school work and getting other projects at home finished up.
    Keep up the good work!
    Edit- so I noticed you looked for the pf48 or whatever filter that was. Is there a reason you didn't swap the fitting in the oil pan so you could use the truck filter instead?
  2. #122
    Mar 2013
    Long Beach California
    The motor was already in the truck and I just couldn't get enough leverage to break it loose from under there. Not much space. Had to go to the auto parts store anyway to get some things and it was only 5 bucks. So I said screw it. Lol
    CALI LEGAL ENGINE SWAP!
  3. #123
    Sep 2012
    Quakertown, Pa.
    ok man, i gotta ask, how the hell do you keep up on oil changes that often? i try but damn... youd have to be checking it constantly to see when it starts to brown... how many miles do you usually get before do a change? and when you do change, do you do the filter too or do you change that like every other fluid change since the oil is staying pretty clean? seems like a lot of work but i gotta hand it to you for staying on top of that....
    I'm always puttering with the truck anyway. Checking for leaks, etc.. While the hood's up, I check the oil. I have roughly 6500 miles since the swap and I've changed the oil and filter 3 times.
    As for how long it goes before getting brown, I guess that would depend on how clean the engine is inside. The only cover I pulled the was the rear main seal cover to replace the seal. By the looks from there, the engine was fairly clean inside(relatively speaking) considering it had 140,000 on it when it went in. I guess I get around 2000 or so miles before it's getting brown enough to change.
    John
  4. #124
    Aug 2012
    Portland, OR
    Got it, makes sense lol.
    Did you end up finding a deal on the oil pan anywhere? I figured I might as well start looking now so I'm not held back by parts when I start working on the swap again. Cheapest I found is this:
    http://www.ebay.com/itm/200921584954...84.m1423.l2649
    Oh one more thing that's different with my swap is that I have an NV3500. So don't have to worry about tranny wiring.
  5. #125
    Mar 2013
    No don't get that! Thats not an ls1 pan! That's an aftermarket pan they try and advertise that will fit anything. It won't work. It will still hang to low. U need an ls1 only pan. Maybe an ls2...?? I saw that too but luckily a member posted a couple pages back that that it wouldn't work before I bought it. unless ur lucky, its gonna be hard to find one for a good deal. I had to sac up and pay 250 cuz I needed it immediately. But it was new and came with everything needed. Theres an article that shows the diff pans and dimensions. Gto won't work either cuz its a front sump. Ill find the link and post it.
    http://www.s10forum.com/forum/f213/l...f-them-324366/
  6. #126
    Aug 2012
    Portland, OR
    Thanks for the heads up, I'll keep looking. Have you added the oil pan kit to your list of part numbers? If worst comes to worst I'll just pick up the same kit.
  7. #127
    Mar 2013
    it wasnt a kit. so theres no part number for it that i know of. im pretty sure it came off a new crate motor that wasnt used.
    and mikey, thats just amazing. especially due to the cost of oil... OUCH!
  8. #128
    Aug 2012
    Portland, OR
    Just to add more information on oil pans. This link has some part numbers that the s10 site doesn't. Mostly the same pans. Hope you don't mind me throwing it up here as well.
    http://ls1tech.com/forums/conversion...-oil-pans.html
  9. #129
    Mar 2013
    well i got some bad news. it wont start. it will crank but wont fire. im sure its something misswired but i dont know where to start. the fuel pump relay is not getting a signal from the pcm. i jumped the terminals to make sure the new pump worked and also to get fuel up to the motor and my gauge read 60psi so all is good there. that tells me there is no injectors or spark or both. and my scanner wont connect to the pcm either. SOUNDS like the computer isnt on but that cant be the case because the pcm makes the starter relay ground, and since my starter is turning, then the computer must be working...right??? But when i turn the key to on, i can hear the TB self adjusting. the computer controls that right? and by the way, i can hear it inside the cab, that sucker is loud....is it supposed to be that loud?
    obviously the next thing im going to do is check out my wiring but how can i check the pcm?? i dont know why my scanner doesnt connect. should i post this in the troubleshooting area? maybe ill get ore responses there?
  10. #130
    Sep 2012
    Quakertown, Pa.
    Was your PCM flashed to remove the VATS? Seems like VATS is cutting out the fuel injectors. It might be something else minor too. Don't overlook anything. When you're this close, check for the things that are obvious and not-so-obvious.
    Not sure if PCM is supposed to be that loud. I can't tell if mine's that loud since it's mounted under the hood. I've never heard it but I will listen for it in the future to see if it makes any noise.
    John
