so has anyone done this with a MAF with the built in air temp? and if so what are the two wires i need ive got the tan wire as th esignal wire but do i need the other wire or does it just need a ground
same wires as in the diagram
2007 RCSB|DTR81 built LSx 3xx|PRC|NX|BOGART|MSD|QUICKFUEL 950 E85|4L80|FTI Converters|Smith RaceCraft|Racepak
midweststreetcars.com
