Results 1 to 10 of 19
Thread: Lsr 215/223??
    Jul 2009
    Lsr 215/223??
    Anyone tried this cam? Massive lift...
    COMP Cams® - Cam Details
    04 Silverado Z-71 Extended Cab
    Magnaflow, 10.4 TV 50 wires, tr-55ix, Synthetics, HID's, JL audio, 33.5", leveling kit, tuned, CAI, vette servo, cam, valve job, pacesetter. 9.3@77.5 and 14.5@93.4
    06 2wd
    custom cam, tune, 3.73's, servo, HID's, 10.4mm wires, long-tubes, CAI, magnaflow, 2.5" shackles, Circle-D 3200, UD, JL Audio 4.1, Alpine 5ch
    wichita falls, tx
    ive noticed most of comps new line of cams are over .600 lift
    Intro Radicalli's
    Nov 2009
    chicago, il
    I'll be running that very cam in a month or so hopefully. I'll post results after install.
    Jul 2009
    Do it! and let us know... most people stay under .600's lift. The duration numbers are also ODD numbers... they have the xer style lobes...
    this particular cam is recommended for 5.3/low end torque/heavy vehicles. The 107 ICL is different too
    06 2wd
    Nov 2009
    chicago, il
    What I do know is, on an L33 like my engine that cam makes very close to 400 crank hp and some really nice torque. I believe it's somewhere around 450 ft lbs. That's what desktopdyno says, and it is a pretty accurate program.
    wichita falls, tx
    put my specs in and see what i should be making hp wise since u have desktop dyno, im curious...mods in sig
    Intro Radicalli's
    Nov 2009
    chicago, il
    Quote Originally Posted by banker099 View Post
    Do you know what you're making? Also, the program rates the power at flywheel.
    wichita falls, tx
    Quote Originally Posted by truckinL33 View Post
    nope ive had the engine in for about 2 weeks, and i have no idea what hp im making
    Intro Radicalli's
    Quote Originally Posted by Tank View Post
    All that means is the cam has 5º of advance ground in. The intake closing event is very similar to the LQ4/LQ9 cam. That's where the low RPM/high torque comes from.
    Jul 2009
    Yea... just saying you don't usually see that much advance on a cam. So would this put out better than like a 212/218 high lift????
    Trying to compare it to something. I'm just worried about the high lift...
    06 2wd
