Results 1 to 10 of 11
Thread: Alarm Question
    AZ
    Alarm Question
    Now that my truck has been broken into twice now, I think its time to start looking into an aftermarket alarm setup. The factory alarm just isnt cutting it, and Id rather not have to replace my system every year!!
    So what alarm system are some of you running? What are your likes or dislikes?
    I like the idea of a keyless entry remote and pager to replace my factory keyfob. I just havnt researched this before and would like some first hand experiences.
    Thanks for any info you can provide.
    '01 ECSB Red 2wd
    7" lift on 17" Eagles and 35" Pro Comps pc'd satin black
    de-badged, smoked tails, grille inserts
    5.3, 91 tuned, cold air,TB spacer, Thorley LT headers, 3" Flowmaster
    4.56 gears, posi-trac
    And more to come
    ff_jeff Guest
    what you do is, leave your window open and wait in a hidden spot with a rifle. Install a radio, with it unplugged and easy to yank. When the fag yanks it out, BOOOM!!! killing spree. naw go with a well know company and dont pinch pennies.
    Viper alarms are about the best you can get. IMO
    wichita falls, tx
    I have the autopage 1000 and I love it because it will page u up to 1 mile away if something happens to your truck
    Mar 2008
    Pearland,Tx
    Get a viper Alarm i heard is good.
    2008 GMC Sierra 5.3
    RCSB
    K&N Intake,Flomaster Dump,3.73,g80
    Comming soon :Cam ,Nelson Tune, LT Headers and the works.
    May 2004
    I've always had good luck with Compustar and Scosche. I have to agree that Viper is getting their S. H. I. T. together with their systems.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    May 2004
    BTW, with Compustar you can hide a Computrack module to follow your vehicle on the internet. It's moreless a GPS............LOL Hello thief!!!
    97 GMC, 2002 LS6.
    Quote Originally Posted by NITROUS View Post
    Might have to get one for my truck, my alarm is ok, but I need a tracking device for it.
    AZ
    My kind of alarm!! BOOM, what was that!!
    Thanks for all the info!!
    I havnt made up my mind yet, Ive been trying to do as much research as posible.
    I like the idea of GPS tracking though....
    '01 ECSB Red 2wd
    And more to come
    More input
    i currently use an autopage system. Works well on PAGEing you if your system is tripped.
    In addition to a remote start, internal Movement/vibration, and glass break options, I have a mercury switch inside the lid on my external toolbox on one of the open inputs on the alarm. Has worked well.
    Regardless of what system you get, if you are having problems w/ people going through your back window like I have, You could put a hood pin switch to your tale gate. If that still doesn't provide you enough piece of minde...Recommend you get an additonal 80-115db siren for inside the cab that runs on a seperate power supply. It doesn't take much to kill an alarm if there is only 1 power supply.
    Hope this helps
    Powder
    2005 RCSB
    4.8 / T76 Front Mount, Cooled, H20 Meth, Nelson Tune
    4L80E w/ Neslon Harness, 3500 stall, 4" Aluminum Shaft, Tru-Trac
    Cal-Tracs
