Results 1 to 2 of 2
Thread: onefastaSSchevy LS1 swap thread
    Well i tore into the truck last weekend and started the project
    heres the specs
    1994 k1500 4wd silverado
    white
    x cab long wheelbase truck
    american racing rims (will be changing later after swap)
    4.10 gears
    flowmaster exhaust
    Swap:
    1998 LS1 and 4l60E from a donor camaro with 80k miles
    2wd LWB driveshaft for 4l60E
    3 wire coolant temp
    new stock 94 Oil pressure Sender (will drill and tap fitting next to oil filter)
    S&P engine mount bracket
    Holley 255LPH fuel pump
    AC delco corvette fuel pump
    Dorman fittings and fuel pressure hose and clamps
    camaro rad fan with harness from donor car
    stock exhaust flanges cut off of cat converters (needed something to weld to lol)
    Some pictures after engine/trans/transfer case removal.
    I will be removing the front diff and taking the front axles down to the outer stubs to bolt into the hubs
    same engine I have but tossed the 98 harness and PCM for a 2002 style.
